How can I change the rootfs (APP) size ?
And how to have two rootfs partitions ?
I tried changing settings in
Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml
For example APPSIZE
and adding
with no success.
Moreover what is the value of APPSIZE and where does it come from?
<partition name="APP" type="data">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> APPSIZE </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 0x8 </allocation_attribute>
<align_boundary> 4096 </align_boundary>
<percent_reserved> 0 </percent_reserved>
<unique_guid> APPUUID </unique_guid>
<filename> APPFILE </filename>
<description> **Required.** Contains the rootfs. This partition must be defined after
`primary_gpt` so it can be accessed as the fixed known special device
`/dev/mmcblk0p1`. </description>
</partition>
