I want to change step_size, but I don’t know how to change that.
Please tell me how to change step_size.
from omni.isaac.examples.base_sample import BaseSample
import numpy as np
from omni.isaac.core.objects import DynamicCuboid
class HelloWorld(BaseSample):
def init(self) → None:
super().init()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
fancy_cube = world.scene.add(
DynamicCuboid(
prim_path="/World/random_cube",
name="fancy_cube",
position=np.array([0, 0, 1.0]),
scale=np.array([0.5015, 0.5015, 0.5015]),
color=np.array([0, 0, 1.0]),
return
async def setup_post_load(self):
self._world = self.get_world()
self._cube = self._world.scene.get_object("fancy_cube")
self._world.add_physics_callback("sim_step", callback_fn=self.print_cube_info) #callback names have to be unique
return
# here we define the physics callback to be called before each physics step, all physics callbacks must take
# step_size as an argument
def print_cube_info(self, step_size):
position, orientation = self._cube.get_world_pose()
linear_velocity = self._cube.get_linear_velocity()
# will be shown on terminal
print("Cube position is : " + str(position))
print("Cube's orientation is : " + str(orientation))
print("Cube's linear velocity is : " + str(linear_velocity))
Hi @Yuya_t - To change the step_size in your script, you need to change the physics settings of the simulation. Here’s the modified scripts:
import numpy as np
import omni.physx as physx
def init(self) -> None:
super().init()
# Set the desired step_size (e.g., 0.01 seconds)
step_size = 0.01
physx.set_time_step(step_size)
return
DynamicCuboid(
name="fancy_cube",
return
self._world.add_physics_callback("sim_step", callback_fn=self.print_cube_info) # callback names have to be unique
return
