this is pin is default configure as Baseboard 40 Pin Header PWM
please download pinmux spreadsheets to change the pin configurations to modify the pin settings.
thanks
you must convert the .dtsi file generated by Excel into a .cfg file,
please check developer guide, pinmux changes.
you’ll need to perform the script, $OUT/Linux_for_Tegra/kernel/pinmux/t19x/pinmux-dts2cfg.py to convert the files.
thanks
