How to change the physical material every 3 seconds
Hi everyone, I’m doing a physical material replacement, and my goal is to randomly change a physical material every three seconds when I run it. (The physical material already exists in my stage). I used an asynchronous operation, a physical step, which didn’t seem right, but I couldn’t find any other way to solve this problem.
If I just used the physics step, it would be changing the physics material every frame, so I used an asynchronous operation, but it didn’t work properly either. Hope to get some help.
import numpy as np
from omni.isaac.core.utils.prims import define_prim
from omni.isaac.core.materials import PhysicsMaterial
import random
import omni.physx as _physx
import omni.usd
import asyncio
import omni.kit.app
import omni.client
from pxr import UsdPhysics
_timeline = omni.timeline.get_timeline_interface()
_physxIFace = _physx.acquire_physx_interface()
def physics_step(step):
    print("start")
    async def a () :
        time = 0.0
        while time < 3.0:
            time = time + await omni.kit.app.get_app().next_update_async(step)
        random_number= random.randint(10, 15)
        print(random_number)
        geometry_prim = GeometryPrim(prim_path="/World/Plane_01")
        geometry_prim.apply_physics_material(PhysicsMaterial(prim_path= f"/World/PhysicsMaterial_test_{random_number}"))
    asyncio.run(a())
_physx_subscription = _physxIFace.subscribe_physics_step_events(physics_step)
_timeline.play()
changing the material should work, why dont you just get the dt from the step and change the material when you hit your counter, something like:
time = 0.0
def _on_physics_step(self, dt):
   time = time + dt
   if time > 3.0:
       # change material
Would that work for you?
Regards,
Ales
