How to change the rgbaimage resolution in driveworks sample –camera_multiple_gmsl?
I am trying to change the rgbaimage resolution in driveworks sample –camera_multiple_gmsl.
My camera resolution is 1920X1208 and i want to change the saved rgba image to 960X600.
I have tried to add
displayImageProperties.width = 960 ;
displayImageProperties.height = 600;
in camera_multiple_gmsl sample code just like below.
dwImageProperties cameraImageProperties;
dwSensorCamera_getImageProperties(&cameraImageProperties, DW_CAMERA_PROCESSED_IMAGE,
cameraSensor[csiPort].sensor);
dwImageProperties displayImageProperties = cameraImageProperties;
displayImageProperties.pxlFormat = DW_IMAGE_RGBA;
displayImageProperties.planeCount = 1;
// format converter
result = dwImageFormatConverter_initialize(&cameraSensor[csiPort].yuv2rgba, &cameraImageProperties,
&displayImageProperties, sdk);
if (result != DW_SUCCESS) {
std::cerr << "Cannot create pixel format converter : yuv->rgba" <<
dwGetStatusName(result) << std::endl;
g_run = false;
break;
I also print out the image size before and after the yuv2rgba format convertion. see the code below.
std::cout << "origin size: " << frameNVMyuv->prop.width << "x" << frameNVMyuv->prop.height << std::endl;
result = dwImageFormatConverter_copyConvertNvMedia(frameNVMrgba, frameNVMyuv, yuv2rgba);
if( result != DW_SUCCESS ){
std::cout << "copyConvertNvMedia: " << dwGetStatusName(result) << std::endl;
std::cout << "transfered size: " << frameNVMrgba->prop.width << "x" << frameNVMrgba->prop.height << std::endl;
The output result is below;
origin size: 1920x1208
Driveworks exception thrown: DW_INVALID_ARGUMENT: FormatConverter (nvmedia): width output != input
copyConvertNvMedia: DW_INVALID_ARGUMENT
transfered size: 960x604
[b]It seems that the image width and height actually changed, but when I use the Takescreenshot function, the images saved were wrong with only 100 Byte which is obviously wrong.
I would really appreciate it if anyone familiar with the driveworks gmsl sample knows how to solve this problem.[/b]
I have tried to add
// format converter
g_run = false;
break;
