Gooddays everyone,When I use spi0 on TX2, (the numbers on the core board are E3, E4, F3, F4). The transmission frequency of SPI is always lower than 1MHz. When I try to use a higher rate, IOCTL () will not report an error, but the actual transmission rate will not increase. My device tree file is as follows:
spi@c260000 {
compatible = "nvidia,tegra186-spi";
reg = <0x0 0xc260000 0x0 0x10000>;
interrupts = <0x0 0x25 0x4>;
nvidia,dma-request-selector = <0x19 0x10>;
#address-cells = <0x1>;
#size-cells = <0x0>;
#stream-id-cells = <0x1>;
dmas = <0x19 0x10 0x19 0x10>;
dma-names = "rx", "tx";
nvidia,clk-parents = "pll_p", "osc";
spi-max-frequency = <0xb71b00>;
clocks = <0xd 0xde 0xd 0x10d 0xd 0x264>;
clock-names = "spi", "pll_p", "osc";
resets = <0xd 0x29>;
reset-names = "spi";
status = "okay";
linux,phandle = <0x81>;
phandle = <0x81>;
spi@0 {
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <0x1312d00>;
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delau = <0x0>;
I would appreciate it if you could help me out.
