How to change the stream source width and height?
System Information
**• DeepStream Version 6.0.1 **
• JetPack Version (4.6.1)
Goal :
My goal is to execute the pipeline on full frame from the CSI camera
Issue:
The current issue is the frame is being cropped to the size of the source, for example, the frame size is 32642464 but on executing the pipeline frame is being cropped to 19201080 which causes the removal of objects present in the frame.
Current Code:
I have already provided the input size of the CSI camera frame, but in the logs i am still getting 1920*1080.
def main(args):
    if len(args) < 1:
        sys.stderr.write("usage: %s <uri1> [uri2] ... [uriN] \n" % args[0])
        sys.exit(1)
    args.append('/dev/video0')
    args.append('/dev/video1')
    global perf_data, gsv, pipeline
    perf_data = PERF_DATA(len(args) - 1)
    number_sources = len(args) - 1
    signal.signal(signal.SIGINT, signal_handler)
    signal.signal(signal.SIGTERM, signal_handler)
    global channel, connection
    try:
        channel, connection = initializeChannel()
    except (pika.exceptions.StreamLostError,
        pika.exceptions.ConnectionClosed,
        pika.exceptions.ChannelClosed,
        pika.exceptions.AMQPConnectionError,
        pika.exceptions.ConnectionWrongStateError,
        ConnectionResetError) as e:
        logger.info("   Failed to establish connection.")
        try:
            connection.close()
        except:
            pass
        logger.info("CIGAR DETECTION MODULE: Deactivated")
        sys.exit()
    except Exception as e:
        print(e)
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    cameras_list = [
        {"source":0, "name":"Camera 1"},
        {"source":1, "name":"Camera 2"},
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streamux \n ")
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for camera in cameras_list:
        source = Gst.ElementFactory.make("nvarguscamerasrc", "source-"+camera['name'])
        if not source:
            sys.stderr.write(" Unable to create Source \n")
        source.set_property('sensor-id',camera['source'])
        source.set_property('bufapi-version', True)
        #source.set_property('width', 3264)  # Change this to the desired width
        #source.set_property('height', 2464)
        caps = Gst.ElementFactory.make("capsfilter", "source-caps-source-"+camera['name'])
        if not caps:
            sys.stderr.write(" Unable to create capsfilter \n")
        caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM),width=(int)3264,height=(int)2464,framerate=(fraction)21/1,format=NV12"))
        pipeline.add(source)
        pipeline.add(caps)
        sinkpad = streammux.get_request_pad('sink_' + str(camera['source']))
        srcpad = source.get_static_pad("src")
        if not sinkpad:
            print("Unable to create source sink pad")
            exit(0)
        if not srcpad:
            print("Unable to create source src pad")
            exit(0)
        srcpad.link(sinkpad)
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    if is_aarch64():
        print("Creating nv3dsink \n")
        sink = Gst.ElementFactory.make("fakesink", "fakesink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        print("Creating EGLSink \n")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    streammux.set_property('width', 3264)
    streammux.set_property('height', 2464)
    streammux.set_property('batch-size', 1)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "configs/pgie_yolov8.txt")
    pgie_batch_size = pgie.get_property("batch-size")
    if (pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
              number_sources, " \n")
        pgie.set_property("batch-size", number_sources)
    tiler_rows = int(math.sqrt(number_sources))
    tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", 3264)
    tiler.set_property("height", 2464)
    sink.set_property("sync", 0)
    sink.set_property("qos", 0)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv.set_property("nvbuf-memory-type", mem_type)
        nvvidconv1.set_property("nvbuf-memory-type", mem_type)
        tiler.set_property("nvbuf-memory-type", mem_type)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(filter1)
    pipeline.add(nvvidconv1)
    pipeline.add(nvosd)
    pipeline.add(sink)
    streammux.link(pgie)
    pgie.link(nvvidconv1)
    nvvidconv1.link(filter1)
    filter1.link(tiler)
    tiler.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    gsv = GenerateSendVideo()
    gsv.start()
    tiler_sink_pad = tiler.get_static_pad("sink")
    if not tiler_sink_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
        GLib.timeout_add(5000, perf_data.perf_print_callback)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(args[:]):
        if i != 0:
            print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        signal_handler(signal.SIGINT, None)
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
    sys.exit(main(sys.argv))
Logs
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 1
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
   Camera index = 0
   Camera mode  = 2
   seconds to Run    = 0
CONSUMER: Producer has connected; continuing.
Screenshots:
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
please refer to this FAQ for How to connect a USB camera in DeepStream?
