I want to update uboot env variable for tx2. Enter into uboot command I can update variable with setenv command. Can we update env variable with follow methods?
- use
sudo ./flash.sh -k kernel jetson-tx2 mmcblk0p1
to update uboot env. Does that means I have to change uboot source code according to env settings? Can you point me out which uboot source file I should changed?
- How to update env under linux? I can build ./fw_printenv with make env under uboot. When execute ./fw_printenv under linux. I get follow error message. Where can I get fw_env.config?
./fw_printenv
Cannot parse config file '/etc/fw_env.config': No such file or directory
- Is there possible to only update env variable directly? I mean env variable is below to special partition? Or is part of uboot partition?
We use JetPack3.2. We found uboot env is stored with kernel/kernel_b partition. This partition store uboot.bin and env variable. Seems no way to update env separately.
sudo gdisk -l /dev/mmcblk0
GPT fdisk (gdisk) version 1.0.1
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/mmcblk0: 61071360 sectors, 29.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Partition table holds up to 29 entries
First usable sector is 4097, last usable sector is 61071327
Partitions will be aligned on 1-sector boundaries
Total free space is 1 sectors (512 bytes)
Number Start (sector) End (sector) Size Code Name
1 4097 18878464 9.0 GiB 0700 APP
2 18878465 18886656 4.0 MiB 0700 mts-bootpack
3 18886657 18894848 4.0 MiB 0700 mts-bootpack_b
4 18894849 18895872 512.0 KiB 0700 cpu-bootloader
5 18895873 18896896 512.0 KiB 0700 cpu-bootloader_b
6 18896897 18897920 512.0 KiB 0700 bootloader-dtb
7 18897921 18898944 512.0 KiB 0700 bootloader-dtb_b
8 18898945 18905088 3.0 MiB 0700 secure-os
9 18905089 18911232 3.0 MiB 0700 secure-os_b
10 18911233 18915328 2.0 MiB 0700 eks
11 18915329 18916536 604.0 KiB 0700 bpmp-fw
12 18916537 18917744 604.0 KiB 0700 bpmp-fw_b
13 18917745 18918744 500.0 KiB 0700 bpmp-fw-dtb
14 18918745 18919744 500.0 KiB 0700 bpmp-fw-dtb_b
15 18919745 18923840 2.0 MiB 0700 sce-fw
16 18923841 18927936 2.0 MiB 0700 sce-fw_b
17 18927937 18940224 6.0 MiB 0700 sc7
18 18940225 18952512 6.0 MiB 0700 sc7_b
19 18952513 18956608 2.0 MiB 0700 FBNAME
20 18956609 19218752 128.0 MiB 0700 BMP
21 19218753 19480896 128.0 MiB 0700 BMP_b
22 19480897 19546432 32.0 MiB 0700 SOS
23 19546433 19611968 32.0 MiB 0700 SOS_b
24 19611969 19743040 64.0 MiB 0700 kernel
25 19743041 19874112 64.0 MiB 0700 kernel_b
26 19874113 19875136 512.0 KiB 0700 kernel-dtb
27 19875137 19876160 512.0 KiB 0700 kernel-dtb_b
28 19876161 20400448 256.0 MiB 0700 CAC
29 20400449 61071326 19.4 GiB 0700 home
I can’t answer your specific question, but you might find some information applies to your case. In the earlier L4T releases device tree was loaded from “/boot” via U-Boot. However, later releases began to require device tree in earlier boot stages, and those earlier boot stages do not know how to read an ext4 partition. Thus much of the content in “/boot” had to go into a binary partition instead. Some releases after that also added a need to sign the partition, and the flash.sh tools do this, but at that point a simple dd to write a partition was no longer possible (you could still use flash.sh tools to create a signed file and dd that, but the process is a bit convoluted).
I know at least part of what U-Boot uses for environment is in the device tree, but other than kernel command line arguments (the “chosen” entry) I’m not sure about the other macros and environment.
