kay1216
1
When checking out the buffer size, it had been 16.
I found out that there is a solution by flashing it.
However, I cannot see any configuration file for jetson orin nx.
The version of jetpack I am using is 5.13.
In the forum, the command is the following:
sudo ./flash.sh -k kernel -C “usbcore.usbfs_memory_mb=512” -k kernel-dtb jetson-xavier mmcblk0p1
What should I replace jetson-xavier with?
kayccc
4
Please use jetson-orin-nano-devkit
since the carrier board is for both Orin NX and Orin Nano modules.
Flashing Support — NVIDIA Jetson Linux Developer Guide 1 documentation
Thanks for your reply.
I have changed the capacity of transfer without flashing jetson.
system
Closed
8
