How to check gpu array values?
hi, i have this code:
extern "C" void myFilter(int *srcHost){
	cufftHandle plan;
	cufftComplex *dstDevice;
	cufftComplex *dstHost;
	cufftReal *srcDevice;
	cudaMallocHost((void **) &dstHost,(N_SAMPLES/2+1)* sizeof(cufftComplex));
	cudaMallocHost((void **) &srcHost,N_SAMPLES* sizeof(int));
	//fill source with desired data
	myMakeSrc_32f(srcHost);
	CUDA_SAFE_CALL(cudaMalloc((void **) &srcDevice,N_SAMPLES* sizeof(cufftReal)));
	CUDA_SAFE_CALL(cudaMalloc((void **) &dstDevice,(N_SAMPLES/2+1)* sizeof(cufftComplex)));
	/* Create a 1D FFT plan. */
	CUFFT_SAFE_CALL(cufftPlan1d(&plan, N_SAMPLES, CUFFT_R2C, 1));
    CUDA_SAFE_CALL(cudaMemcpy(srcDevice, srcHost, N_SAMPLES, cudaMemcpyHostToDevice));
	/* Use the CUFFT plan to transform the signal in place. */
	CUFFT_SAFE_CALL(cufftExecR2C(plan, srcDevice, dstDevice));
    CUDA_SAFE_CALL(cudaMemcpy(dstHost, dstDevice, N_SAMPLES/2+1, cudaMemcpyDeviceToHost));
	/* Destroy the CUFFT plan. */
	cufftDestroy(plan);
(i do know i have to free all the pointers in the end, this is just testing)
i need to know what values the dstHost array contains, how can i do that? the “normal” C++ way doesn’t work because the values don’t show up on the tooltip…
this is a MFC application in VS05.
thanks
