I’ve installed cuda-toolkit-11-2
Runtime Library by following instructions from the official website here, with a slight change in the last step. Instead of sudo apt-get install cuda
I did sudo apt-get install cuda-toolkit-11-2
. I’m using Linux Mint 20.1.
After that I installed cuDNN, or I should say copied and pasted the files from the tar
archive to cuda
folder on my system as directed here.
But I’m unable to verify this test as I did not get the cudnn from a deb file.
My concern is how to check if cudnn is correctly configured with cuda toolkit.
I have tried solution here but cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2
gives no output. Even whereis cudnn.h
gives just cudnn:
and nothing else.
However,
function lib_installed() { /sbin/ldconfig -N -v $(sed 's/:/ /' <<< $LD_LIBRARY_PATH) 2>/dev/null | grep $1; }
function check() { lib_installed $1 && echo "$1 is installed" || echo "ERROR: $1 is NOT installed"; }
check libcudnn
this thing gives output that libcudnn is installed
. I’m really not sure if everything is in place and correct or not.
Any help would be appreciated. Thanks in advance.
