How to check parameters passed to cuda runtime API deep inside a function is correct when writing unit test?
Suppose I have a resource management class as below:
class CudaDeviceMem {
public:
        CudaDeviceMem(size_t bytes) {
                cudaMalloc(&ptr, bytes);
       ~CudaDeviceMem(){
                release();
        void release(){
                cudaFree(ptr);
private:
       void *ptr;
I want to write a unit test to check whether memory is allocated as I wish. So I write pseudo-code as below:
//Google unit test
TEST(MyTest,  AllocTest){
      CudaDeviceMem mem(10);
      //Check cudaMalloc is called with parameter 10.
      //How to do this?
Any idea? Thanks a lot.
I would say it is not possible. But you can simply check the return status of cudaMalloc directly.
cudaError_t status = cudaMalloc(&ptr, bytes);
if(status != cudaSuccess){
  handleError()
(On a side note: If you want a tested wrapper for device allocations, you could use Thrust or RMM)
