How to check the device on PEX2? We have used the command ‘lspci’ but it has not responded.
We are using r28 BSP.
Normally, if lspci does not show anything, I would expect the signal quality is too degraded. I couldn’t tell you how to get any verbose debug message, but I too would be curious if there a lower level way to see what PCI is doing.
I’ll check it, thank you very much!
