how to check the installation?
Hi, Dear
I install the pgi 5.2 on Fedora 3 for your colleauge’s help.
and When I excuted the file, the results are difference before.
I think installation was not complete, but there are any error message.
How do I check the installaion?
Best regards,
Yongjoo CHOI
Assume you install on /usr/pgi/linux86/5.2
% setenv PATH /usr/pgi/linux86/5.2/bin:$PATH
Then write a simple program such as hello world or even empty program.
% cat >hello.f
print *, “Hello World\n”
Control-C
%pgf90 hello.f
%./a.out
If it prints Hello World then you are set. If not, contact trs@pgroup.com.
Hongyon
Hi, Dear.
The pgi 7.1.6 doesn’t support to Fedora 8?
If the pgi 7.1.6 support only fedora 7, is it same method to install pgi 5.2.
I ask that there are some patch for Fedora as need to install pgi 5.2.
Thank you for reading my message.
Regards.
You should be able to install 7.1-6 fedora8. If not, please contact trs@pgroup.com and ask how to do it. No, the patch for 5.2 for fedora3 and 7.1-6 for fedora8 will not be the same.
Hongyon
