How to check TX2 GPU onboard usage
I am running a program on TX2 and I want to check the usage of GPU resources. For example, when running the program ,how to check the ratio :used/total.
I have used the ‘sudo ~/tegrastats’ to check and found the usage of RAM and other indexs which I don’t understand.
thank you .
You can find the information in our L4T document:
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28-2-ga
Applications and Tools
TegraStats Utility
