It seems that array reduction starts to be supported in OpenACC API 2.7 (https://www.openacc.org/blog/whats-new-openacc-27), but I cannot find information/confirmation on whether API 2.7 has been fully adopted by the PGI compiler 19.4. I tried the PGI compiler release notes (https://www.pgroup.com/resources/docs/19.9/x86/pgi-release-notes/index.htm) and the API 2.7documentation (https://www.openacc.org/sites/default/files/inline-files/OpenACC.2.7.pdf).
As a general question, how can I check which version of OpenACC API is being used by the PGI compiler I am currently using?
Thanks,
Shine
Hi Shine,
We’re still in the process of adding the new OpenACC 2.7 features with PGI 19.10 currently support up to the 2.6 standard.
The “_OPENACC” macro is defined to the standard’s release date. With 2.6 being “201711” and 2.7 using “201811”.
For example:
% cat test.F90
program foo
use openacc
print *, _OPENACC
end program foo
% pgfortran -acc test.F90
% a.out
201711
Hope this helps,
Mat
Thanks, Mat, for your helpful information. Yes, with your code, I can tell that my PGI 19.4 is using the OpenACC API 2.6.
Thanks,
Shine
Hi Mat:
I was looking at this post and tried the following:
program foo
use openacc
print *, _OPENACC
end program foo
Then I compile with
C:\brandnewR>pgfortran -acc test.f90
./test.exf: warning: unknown section "_RDATA" found, executable not
stripped. Use the linker's /merge option to merge this section
with another. Example: "/merge:_RDATA=.data"
C:\brandnewR>test.exe
0.000000
I’m using Windows with Community edition. What am I doing wrong, please?
Thanks,
Erin
Hi again!
I used the -cpp option during compilation and it worked fine.
Thanks though!
Sincerely,
Erin
Hi Erin,
FYI, “.F90” suffix will have the compiler implicitly preprocess the source file. However “.f90” are not preprocessed by default. For these files, you’ll need to add “-Mpreprocess” or, as you note, “-cpp”.
-Mat
