The sudo swapoff command I found was only temporarily turned off, but the swap partition was still automatically enabled after restarting
Hi 1056706260,
Are you using the devkit or custom board for Orin NX?
Please share the full serial console log for further check.
jetpack version: 5.1.1
I am using the devkit
Hi Team,
Any feedback?
Put the log here.
Using the sudo swapoff -a command, I can only temporarily disable the swap partition. After the restart, the swap partition will reappear
What we want to check is the serial console log, you can refer to the following link to get this log from the devkit.
Jetson Nano & NX Style - Serial Debug Console - JetsonHacks
