How to close the gpu module?
please help me, thank you.
Hi wm18822827507,
May I know why you want to disable the GPU module? Any specific requirement?
If just want to monitor the usage, you can use tegrastats, see: https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2FAppendixTegraStats.html%23
I want to know if CPU performance can be improved after shutting down or reducing gpu performance. I need CPU to be faster
I don’t think disable GPU help CPU performance. You can boost the CPU performance from below command.
sudo su
nvpmodel -m 0
jetson_clocks
