I have overloaded the “*”-operator such that now I can use it with
a REAL and a self-defined type. When I have a line z = x * y, all goes well.
When I have z = -1. * y, I get “unknown result for arithmetic operation”.
This can be repaired by coding z = (-1.) * y
I find this solution a nuisance and would like to have my operator
recognize -1. as a valid first arguement.
Do you have an interface for real and user defined type and vice versa? If not, you will need ones.
After you have created an interface for realuser_defined_type and user_defined_typereal, a workaround for now is below.
Note that currently we have a bug at compile time when passing negative real constant to overloaded operator *. As * has higher precedence than - and the compiler does not handle it correctly. I have filed a TPR #14395.
passing a variable instead of constant
For example, real abc = -1.0
…= abc * your_user_defined_type_variable
put constant as a second operand.
…=your_user_defined_type_variable * -1.0
I would like to correct the above comment I just made. Actually, -1.0 * user_defined_type won’t work the way you want it to be because * has higher precedence and hence it the interpretation in Fortran is -(1.0 * user_defined_type). That means you will need to put () or store -1.0 in a variable.
Now regarding a TPR, we still need to fix the problem and gives an appropriate warning message when user try to do that.
