How to communicate stm32 with jetson agx orin over the I2S Peripheril
well i want to try audio transfer from jetson agx to stm32 wl33 but i cant.
normally I can listen audio from inmp441 mic with stm32 and working properly.
like this:
now I want to listen over the jetson agx . so what should do in terminal to get same format output.
Do you configure Tegra I2S as Master or Slave mode?. Also provide if any change did on driver/DT side. Did you confirm that I2S signals are coming out of IGX during usecase?
hi,
ı have test as slave or master but result is same there are a noise. on the other hand I can send audio from stm32 to Jetson AGX properly. but I can not send jetson agx to stm32.
when I send data stm32 to AGX I am using this parameters:
sudo /opt/nvidia/jetson-io/jetson-io.py
sudo arecord -l | grep -i admaif1
sudo amixer -c 1 controls | grep -i i2s2
sudo amixer -c 1 cset name="I2S2 codec master mode" cbm-cfm
sudo amixer -c 1 cset name="I2S2 codec frame mode" i2s
sudo amixer -c 1 cset name="I2S2 Sample Rate" 8000
sudo amixer -c 1 cset name="I2S2 Client Bit Format" 16
sudo amixer -c 1 cset name="I2S2 Client Channels" 2
sudo amixer -c 1 cset name="I2S2 Capture Audio Bit Format" 16
sudo amixer -c 1 cset name="I2S2 Capture Audio Channels" 2
sudo amixer -c 1 cset name="ADMAIF1 Mux" I2S2
sudo amixer -c 1 cget name="I2S2 codec master mode"
sudo arecord -D hw:1,0 -r 8000 -f S16_LE -c 2 -d 5 -v test.wav
sudo aplay -D plughw:2,0 -r 8000 -f S16_LE -c 2 test.wav
actually I didnt understand this codes, ı have asked gpt.
if I debug the stm32 for incoming data I see this buffer (incorrect and unwanted)
also I have test to send 0 (zero) jetson agx to stm32 , I can see at stm32 debug side zeros
if everthing works fine I will see this output from stm32 side, I got this output while I was listening inmp441 mic over the i2s.
hi reply is above
Thanks for the info, from your comment I2S2 was used in slave mode. Did you make sure the clock from stm32 reaches AGX when you start the usecase. you can check debugging tips @ Audio Setup and Development — NVIDIA Jetson Linux Developer Guide .
you can attach the kernel dmesg log taken during usecase to check if any error seen.
