How to compile and install netcdf-4 (C and Fortran) with nvidia c and fortran compiler
Hi.
Is there a guide or a reference for a complete installation (and compilation) of netcdf4 with nvidia compilers instead of gnu compilers?
Many thanks in advance.
Try this. I use the 22.7 release here, but feel free to substitute your own preferred version. Note we have not tested HDF5 1.13.x nor NetCDF-C 4.9.0 here yet, so if these versions have issues, I would suggest dropping back to previous versions and filing a report. Also tailor $DESTDIR below according to your needs:
DESTDIR=/path/to/netcdf/will/be/installed
module load nvhpc/22.7
wget https://support.hdfgroup.org/ftp/lib-external/szip/2.1.1/src/szip-2.1.1.tar.gz
tar xvaf szip-2.1.1.tar.gz
cd szip-2.1.1
mkdir build
cd build
../configure CC=nvc \
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make -j
make install
cd ../..
wget https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.13/hdf5-1.13.2/src/hdf5-1.13.2.tar.gz
tar xvaf hdf5-1.13.2.tar.gz
cd hdf5-1.13.2
mkdir build
cd build
../configure CC=mpicc FC=mpifort \
    CFLAGS="-fPIC -O1" \
    FCFLAGS="-fPIC -O1" \
    --enable-shared \
    --enable-static \
    --enable-fortran \
    --enable-hl \
    --enable-parallel \
    --with-zlib \
    --with-szlib=$DESTDIR \
    --prefix=$DESTDIR
make -j
make install
cd ../..
wget https://github.com/Unidata/netcdf-c/archive/refs/tags/v4.9.0.tar.gz && \
    mv v4.9.0.tar.gz netcdf-c-4.9.0.tar.gz
tar xvaf netcdf-c-4.9.0.tar.gz
cd netcdf-c-4.9.0
mkdir build
cd build
../configure CC=mpicc \
    CFLAGS="-fPIC -O1"
    CPPFLAGS="-I$DESTDIR/include" \
    LDFLAGS="-L$DESTDIR/lib" \
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make -j
make install
cd ../..
wget https://github.com/Unidata/netcdf-fortran/archive/refs/tags/v4.6.0.tar.gz && \
    mv v4.6.0.tar.gz netcdf-fortran-4.6.0.tar.gz
tar xvaf netcdf-fortran-4.6.0.tar.gz
cd netcdf-fortran-4.6.0
    CFLAGS="-fPIC -O1 -I$DESTDIR/include" \
    LDFLAGS="-L$DESTDIR/lib -lnetcdf -lhdf5_hl -lhdf5" \
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make
make install
Hope this helps.
Many thanks for your help.
Unfortunately this is not working because netcdf configuration does not find the “hdf5.h”.
checking hdf5.h usability... no
checking hdf5.h presence... no
checking for hdf5.h... no
configure: error: Compiling a test with HDF5 failed.  Either hdf5.h cannot be found, or config.log should be checked for other reason.
I checked, and with a previous version of hdf5 (1.12.2) the file hdf5.h exists. I don’t understand.
This error is cause by the lack of "" at the end of the CFLAGS line when configure netcdf-c.
But after that, I get this error:
configure: error: cannot compute sizeof (off_t)
Great. I can successfully complete the installations now. @utente731 @cparrott
Here is final script I use (several locations are modified),
DESTDIR=/home/A10002/lkuang/library
#module load nvhpc/22.7
cd szip-2.1.1
mkdir build
cd build
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make -j
make install
cd ../..
cd hdf5-1.13.2
mkdir build
cd build
    --enable-shared \
    --enable-static \
    --enable-fortran \
    --enable-hl \
    --enable-parallel \
    --with-zlib \
    --prefix=$DESTDIR
make -j
make install
cd ../..
cd netcdf-c-4.9.0
mkdir build
cd build
######## Add these 2 lines #########
export LIB_NETCDF=$DESTDIR/lib
export LD_LIBRARY_PATH=$LIB_NETCDF:$LD_LIBRARY_PATH
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make -j
make install
cd ../..
make build && cd build  ## Add this line
    --enable-shared \
    --enable-static \
    --prefix=$DESTDIR
make
make install
PS: the error in my last post is solved from this page.
