I’ve been using Xavier before;
Now using Xavier NX, what is the difference between compiling and burning SDK, etc., is there any documentation to explain!!
thanks
thanks
Hi JiaZW,
Please download this SD Card Image
Then follow these instructions
You can also refer to Jetson Linux Developer Guide.
I mean compile the SDK for public_sources.tbz2, kernel_src.tbz2;
not mean installing a native system
Xavier and NX are used same kernel Image. For the flash only the configure different like below.
sudo ./flash jetson-xxxx
