I just don’t know what I should do to compile mu cuda code *.cu into MATLAB I asked the MATLAB forum but they don’t give me any anser and when I contact the technical department they said they don’t support studentes question.It is really kinlling me to read many many people soultion and don’t fix my problem
nvcc fatal : Visual Studio configuration file ‘vsvars32.bat’ could not be found for installation at ‘C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.1\bin/…/…/…’
where can I find this ‘vsvars32.bat’ then where do I have to put it
if there is any comand that I can just write in command window matlab and install all nvcc problem as I undrestand from some topic please provide me
Thank about your efoort just want to know how can I find this file
C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin\amd64>nvcc example.cu
d for installation at ‘./…/…/…’
do I need to have Microsoft Visual Studio to run JAKET too I hate configration and setup
To clarify on my earlier statement, you only need a “Visual C++ Runtime” to run Jacket, which is usually present in most Windows Operating Systems, and can be installed in a few seconds. To use the Jacket SDK, you do need the Visual Studio environment, as the Jacket SDK needs a compiler.
