How to compile jetson linux kernel 5.10.120 to x86_64 platform?
Needs to be compiled to arm64(AGX Xavier) and x86_64.
Use x86_64_defconfig and modify its contents
Currently this error occurs:
kernel/nvgpu/drivers/gpu/nvgpu/include/nvgpu/static_analysis.h:820:2: error: #error "__ARM_FEATURE_UNALIGNED not defined. Check static_analysis.h"
How can I fix it?
Seeking help, thank you.
My goal is to compile a set of code to run on multiple platforms.
Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
