How to compile & run the PhysX 4 demos and examples on Linux(Ubuntu 18 LTS)?
I Posted this on StackOverflow.
[url]what are the steps to compile and run NVIDIA PhysX (version4) Kapla Demo and sample code using cmake? - Stack Overflow
I am trying to get into NVIDIA PhysX SDK. But cannot find how to actually run the following,
Kapla Demo:
[url]https://github.com/NVIDIAGameWorks/PhysX/tree/4.1/kaplademo[/url]
Other Samples:
[url]https://github.com/NVIDIAGameWorks/PhysX/tree/4.1/physx/samples[/url]
i followed the instructions here,
[url]http://gameworksdocs.nvidia.com/PhysX/4.1/documentation/physxguide/Manual/BuildingWithPhysX.html[/url]
to get a build with
sudo ./generate_projects linux
and ended up with a document hierarchy that i cannot make heads or tails of.
it would be great if i can link the Kapla Demo and other Examples with a single CMake script. All help is much much appreciated.!
Kapla demo does not support linux and there is no plan to add it. As for samples, we will add all the required files to compile samples on linux in next update. However it is recommended to use snippets that demonstrate most of the SDK features.
Regards,
Ales
