data with its size larger than mtu,the host will rdma-write fragments to the remote(mellanox cx5),but the remote not reply an ack to each fragment . it cause the number of acks and fragments is not equal .How do I configure the remote so that it reply an ack to each fragment?
You can try the following:
Configure the socket option TCP_NODELAY in the application that uses RDMA.
Adjust the MTU size to a value that minimizes fragmentation. If possible, enable jumbo frames (9000 bytes) if your network supports it.
Use the ibv_modify_qp API to configure specific QP attributes that control packet transmission and acknowledgment behavior.
f you’re using RoCE, ensure ECN is properly configured to help with congestion management.
Regards,
Chen
