How to configure a GPIO on the Jetson Orin Nano as an interrupt input? (GPIO Interrupt Configuration and Validation)
Hi Team,
We are using the NVIDIA Jetson Orin Nano EVK board and need to configure a GPIO pin as an interrupt input.
Could you please guide us on:
  • What device-tree changes are required to configure and bind the GPIO pin as an interrupt?
  • How can we correctly configure the pinmux/GPIO settings for interrupt functionality?
  • How can we validate on Linux whether the GPIO is working correctly and generating interrupts?
Nisarg
hello nisarg.prajapati,
may I know what’s the public release version you’re working with.
also, which GPIO pin you’re going to enable as an interrupt?
you may check developer guide, MB1 Configuration Changes.
please refer to pinmux spreadsheet to update the pin usage, for instance, you should configure the selected pin direction as Bidirectional. you should perform a full reflash to apply pinmux changes.
BTW, please see-also Topic 192147 as reference.
