How to configure AGX Orin PCIE controller C7 as endpoint
Hi
I saw this ODMDATA value can set pcie c5 as endpoint.
ODMDATA="**gbe-uphy-config-22,nvhs-uphy-config-1,hsio-uphy-config-0**,gbe0-enable-10g,hsstp-lane-map-3";
What is the ODMDATA value for pcie c7 as endpoint?
thx
Yen
Sorry for the late response, is this still an issue to support? Thanks
After you change to config #2 . Go to device tree and set the PCIe C7 node with ep suffix as enabled.
Also, disable the PCIe C7 RP node.
