OS is Windows 10 Professional (64-bit), version 1803, build 17134.48.
IDE is Visual Studio 2017 Community, version 15.7.3.
CMake is 3.11.3 (64-bit).
I’m running latest CodeWorks for Android 1R7.
Here’s a simple CMakeLists.txt file:
cmake_minimum_required(VERSION 3.9)
project(CMakeAndroidTest)
add_executable(cmake-android-test main.cpp)
And here’s a minimalistic main.cpp file:
int main()
return 0;
If I run CMake from the command-line using the above build environment, I’m getting VS projects/solution files tailored for gcc 4.9, targeting Android 9 API, using gnustl_static STL, without support for RTTI nor exceptions:
C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build>cmake … -G “Visual Studio 15 2017” -DCMAKE_SYSTEM_NAME=Android
– The C compiler identification is GNU 4.9.0
– The CXX compiler identification is GNU 4.9.0
– Check for working C compiler: C:/NVPACK/android-ndk-r15c/toolchains/arm-linux-androideabi-4.9/prebuilt/windows-x86_64/bin/arm-linux-androideabi-gcc.exe
– Check for working C compiler: C:/NVPACK/android-ndk-r15c/toolchains/arm-linux-androideabi-4.9/prebuilt/windows-x86_64/bin/arm-linux-androideabi-gcc.exe – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: C:/NVPACK/android-ndk-r15c/toolchains/arm-linux-androideabi-4.9/prebuilt/windows-x86_64/bin/arm-linux-androideabi-g++.exe
– Check for working CXX compiler: C:/NVPACK/android-ndk-r15c/toolchains/arm-linux-androideabi-4.9/prebuilt/windows-x86_64/bin/arm-linux-androideabi-g++.exe – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Configuring done
– Generating done
– Build files have been written to: C:/Users/ema/Documents/Visual Studio 2017/Projects/CMakeAndroidTest/build
OK, fine.
Now, I’m trying to customize the toolchain, Android API, STL library or RTTI/exceptions support by defining the following variables in CMakeLists.txt:
set(ANDROID_TOOLCHAIN clang)
set(ANDROID_PLATFORM android-24)
set(ANDROID_STL libc++)
set(ANDROID_CPP_FEATURES “rtti exceptions”)
set(ANDROID_ARM_NEON TRUE)
Absolutely no effect (yes, I clean up CMake cache between each CMake run). I’m getting no error, but it’s as if the variables aren’t taken into account.
So, rather than trying to refine the toolchain myself, I thought that using the default android.toolchain.cmake file provided by Android NDK r15c included with CodeWorks for Android 1R7 would do the trick for me. Nope, I’m simply unable to create VS projects/solution files:
C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build>cmake … -DCMAKE_TOOLCHAIN_FILE=C:\NVPACK\android-ndk-r15c\build\cmake\android.toolchain.cmake
– Building for: Visual Studio 15 2017
– Check for working C compiler: C:/NVPACK/android-ndk-r15c/toolchains/llvm/prebuilt/windows-x86_64/bin/clang.exe
– Check for working C compiler: C:/NVPACK/android-ndk-r15c/toolchains/llvm/prebuilt/windows-x86_64/bin/clang.exe – broken
CMake Error at C:/Program Files/CMake/share/cmake-3.11/Modules/CMakeTestCCompiler.cmake:52 (message):
The C compiler
"C:/NVPACK/android-ndk-r15c/toolchains/llvm/prebuilt/windows-x86_64/bin/clang.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Users/ema/Documents/Visual Studio 2017/Projects/CMakeAndroidTest/build/CMakeFiles/CMakeTmp
Run Build Command:"C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/MSBuild/15.0/Bin/MSBuild.exe" "cmTC_097ff.vcxproj" "/p:Configuration=Debug" "/p:VisualStudioVersion=15.0"
Microsoft (R) Build Engine version 15.7.179.6572 pour .NET Framework
Copyright (C) Microsoft Corporation. Tous droits réservés.
La génération a démarré 14/06/2018 15:35:38.
Projet "C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\cmTC_097ff.vcxproj" sur le noud 1 (cibles par défaut).
PrepareForBuild:
Création du répertoire "cmTC_097ff.dir\Debug\".
Création du répertoire "C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\Debug\".
Création du répertoire "cmTC_097ff.dir\Debug\cmTC_097ff.tlog\".
InitializeBuildStatus:
Création de "cmTC_097ff.dir\Debug\cmTC_097ff.tlog\unsuccessfulbuild", car "AlwaysCreate" a été spécifié.
ClCompile:
C:\NVPACK\android-ndk-r15c\toolchains\arm-linux-androideabi-4.9\prebuilt\windows-x86_64\bin\arm-linux-androideabi-g++.exe
testCCompiler.c
arm-linux-androideabi-g++.exe : error : unrecognized command line option '-fno-integrated-as' [C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\cmTC_097ff.vcxproj]
arm-linux-androideabi-g++.exe : error : unrecognized command line option '-fno-limit-debug-info' [C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\cmTC_097ff.vcxproj]
Génération du projet "C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\cmTC_097ff.vcxproj" terminée (cibles par défaut) -- ÉCHEC.
ÉCHEC de la build.
"C:\Users\ema\Documents\Visual Studio 2017\Projects\CMakeAndroidTest\build\CMakeFiles\CMakeTmp\cmTC_097ff.vcxproj" (cible par défaut) (1) ->
(ClCompile cible) ->
0 Avertissement(s)
2 Erreur(s)
Temps écoulé 00:00:00.68
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:2 (project)
– Configuring incomplete, errors occurred!
See also “C:/Users/ema/Documents/Visual Studio 2017/Projects/CMakeAndroidTest/build/CMakeFiles/CMakeOutput.log”.
See also “C:/Users/ema/Documents/Visual Studio 2017/Projects/CMakeAndroidTest/build/CMakeFiles/CMakeError.log”.
Can you see? Process starts up correctly using CLang as C++ compiler and then, all of a sudden, switch/revert to arm-linux-androideabi-g++ during compiler checks. What’s going on?
So, in short, what’s the right way to customize toolchain with CodeWorks for Android? I know how to switch to CLang from within VS once the projects/solution files have been generated [1] but this is not what I want to do; I want my VS projects/solution files generated from scratch to use CLang, using the chosen STL library, etc. As previously explained, defining the appropriate (I think) variables in CMakeLists.txt has no effect. Passing thel as CMake arguments from within the command-line doesn’t work either. Flags that I’ve tried without a success for e.g. switching to CLang:
-DCMAKE_ANDROID_NDK_TOOLCHAIN_VERSION=clang
-DCMAKE_ANDROID_TOOLCHAIN=clang
-DCMAKE_ANDROID_TOOLCHAIN_NAME=clang
(All tried out with/without CMAKE_ prefix; no luck).
BTW, the variables documented in android.toolchain.cmake are different than the ones in CMake | Android NDK page [2]. Which ones to use?
Thanks for reading.
Émeric
[1] https://devtalk.nvidia.com/default/topic/987665/nsight-tegra-visual-studio-edition/clang-on-android/
[2] https://developer.android.com/ndk/guides/cmake
