How to configure interrupts in DTS for mcp2515 on Xavier NX
Hi!
I’m trying to connect mcp2515 on Xavier NX in order to implement another canbus interface.
I used the results of the most relevant thread How to enable MCP2515 on Xavier-NX
So I retrieved DTS from kernel_tegra194-p3668-all-p3509-0000.dtb, made modifications in the tree with the following lines (after preprocessing)
 can_clock: can_clock {
  compatible = "fixed-clock";
  #clock-cells = <0>;
  clock-frequency = <20000000>;
  clock-accuracy = <100>;
 spi@3230000 {
  spi@0 {
   status = "okay";
   compatible = "microchip,mcp2515";
   reg = <0x0>;
   spi-max-frequency = <10000000>;
   nvidia,enable-hw-based-cs;
   clocks = <&can_clock>;
   interrupt-parent = "/gpio@2200000";
   interrupts = < ((24 * 8) + 4) 0x1 >;
I got the line “interrupts = < ((24 * 8) + 4) 0x1 >;” from “interrupts = <TEGRA194_MAIN_GPIO(Y, 4) 0x1>;” after preprocessing (cpp -E -undef -x assembler-with-cpp kern.dts kern.dts.preprocessed)
Then I call
dtc -f  -@ -I dts -O dtb -o custom.dtb kern.dts.preprocessed
and I got an error:
dtc: livetree.c:437: propval_cell: Assertion `prop->val.len == sizeof(cell_t)’ failed.
If I remove line “interrupts = < ((24 * 8) + 4) 0x1 >;” from the section, then compilation finish successfully.
Could you please help me to configure interrupts for mcp2515 properly?
Sorry for the late response, have you managed to get issue resolved? Thanks
