To configure PWM01 and GPIO35 as PWM
Here are the steps:
lion@lion:~/nvidia/xavier16G-jp4.2.3/JetPack_4.2.3_Linux_GA_P2888/Linux_for_Tegra/kernel/pinmux/t19x$ python pinmux-dts2cfg.py --pinmux --mandatory_pinmux_file mandatory_pinmux.txt addr_info.txt gpio_addr_info.txt por_val.txt tegra19x-jetson_agx_devkit-pinmux.dtsi tegra19x-jetson_agx_devkit-gpio-default.dtsi 1.0 > tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
But it will report an error.
ERROR: pin dap1_sclk_ps0(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap1_fs_ps3(0x00000440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_rd3_pf1(0x00022470) field nvidia,lpbk(0x00000020) is not matching, val = 0x01 expected = 0x00
ERROR: pin eqos_sma_mdio_pf4(0x00022440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin sdmmc4_cmd(0x00002440) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio10_pg6(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin soc_gpio13_ph1(0x00000411) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm2_px2(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin gp_pwm3_px3(0x00000410) field nvidia,tristate(0x00000010) is not matching, val = 0x01 expected = 0x00
ERROR: pin uart2_tx_px4(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart2_rts_px6(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart5_tx_py5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart5_rts_py7(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin uart3_tx_pcc5(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin soc_gpio22_pq2(0x00000459) field nvidia,pull(0x0000000c) is not matching, val = 0x02 expected = 0x00
ERROR: pin uart1_tx_pr2(0x00000400) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
ERROR: pin dap4_sclk_pa4(0x0000c440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin dap4_fs_pa7(0x0000c440) field nvidia,enable-input(0x00000040) is not matching, val = 0x01 expected = 0x00
ERROR: pin ufs0_ref_clk_pff0(0x00022420) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x01
ERROR: pin ufs0_rst_pff1(0x00022420) field nvidia,pull(0x0000000c) is not matching, val = 0x00 expected = 0x02
- How to convert dtsi file to cfg file?
- How to use PWM for Xavier?
