I’ll provide a comprehensive answer to your question about configuring security registers in the bootloader for the Jetson Orin Nano.
Security Registers and TrustZone Protection Controller (TZPC)
The security registers you mentioned (e.g., scr06, scr16, scr26, etc.) are part of the Platform Security Controller (PSC) and are used to configure the TrustZone Protection Controller (TZPC). The TZPC is responsible for controlling access to peripherals and memory regions, ensuring that only the secure world can access sensitive resources.
Configuring Security Registers
The values you provided (e.g., 0x3c001010) are likely hexadecimal representations of the security register settings. These values are typically set in the bootloader, specifically in the MB1 (Memory Boot 1) stage, which is responsible for initializing the security configuration.
To configure these security registers, you’ll need to modify the MB1 bootloader code. The exact steps will depend on the specific bootloader implementation and the development environment you’re using.
MB1 Security Configuration
The MB1 security configuration is indeed the place where you can set peripherals as secure for the TrustZone secure world via the TZPC. The MB1 bootloader is responsible for initializing the security configuration, including setting the security registers.
In the context of the Jetson Orin Nano, the MB1 bootloader is typically responsible for:
- Initializing the PSC and TZPC.
- Configuring the security registers to set peripherals as secure or non-secure.
- Enabling or disabling TrustZone features, such as secure boot and secure debug.
Configuring Peripherals as Secure
To set peripherals as secure, you’ll need to modify the MB1 bootloader code to configure the security registers accordingly. This typically involves setting the corresponding bits in the security registers to enable or disable access to specific peripherals.
For example, to set a peripheral as secure, you might need to set a specific bit in the scr06 register to 1. This would indicate that the peripheral is only accessible from the secure world.
Development Environment and Tools
To modify the MB1 bootloader code, you’ll need to use a development environment and tools that support the Jetson Orin Nano platform. This might include:
- NVIDIA’s L4T (Linux for Tegra) development environment.
- The NVIDIA Jetson SDK.
- A code editor or IDE (Integrated Development Environment) that supports the MB1 bootloader code.
Example Code
Unfortunately, I don’t have access to the specific code examples for the Jetson Orin Nano platform. However, I can provide a general example of how you might configure a security register in the MB1 bootloader code:
// Example code to configure security register scr06
#define SCR06_SECURE_BIT (1 << 0)
void configure_security_registers(void) {
// Initialize the PSC and TZPC
psc_init();
tzpc_init();
// Configure security register scr06
uint32_t scr06_value = SCR06_SECURE_BIT;
write_security_register(SCR06, scr06_value);
This example code initializes the PSC and TZPC, and then configures the scr06 security register to set a specific peripheral as secure.
Conclusion
Configuring security registers in the bootloader for the Jetson Orin Nano requires modifying the MB1 bootloader code to set peripherals as secure or non-secure. This involves initializing the PSC and TZPC, configuring the security registers, and enabling or disabling TrustZone features.
I hope this comprehensive answer helps you understand how to configure security registers in the bootloader for the Jetson Orin Nano. If you have further questions or need more specific guidance, feel free to ask.
