How to configure SPI2 as a slave?
Just configure the spix_[miso/mosi/sck]_xx as 0x00000444 and spix_csx_xxx as 0x00000448 to try.
1: Your suggestion is setting the SPI1 and SPI3 loopback mode?
2: Now i use the FPGA make the SPI1 Pin send singnal direct to the SPI2 pin for test, what’s the pinmux setting for this.
3: Would you give me the spidev_test.c code
  1. No, just any of SPI connect loopback with SPI2, due to you want to have SPI2 as slave.
  2. Don’t understand this. Should be FPGA connect to SPI2 why involve SPI1?
  3. You can get the source code from public, Sorry can public this with internal modification.
Hi ShaneCCC
now i am confused of the information you give me, so i want to make it clear and ask you some questions.
1: Whatever the SPI pin mode is master or slave, what’s the setting of SPI pinmux, is it part1 or part2? which is useful?
#part1
pinmux.0x0243d040 = 0x00000450; # spi1_sck_pz3: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d020 = 0x00000450; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d058 = 0x00000450; # spi1_miso_pz4: rsvd1, pull-down, tristate-enable, input-enable, lpdr-disable
pinmux.0x0243d010 = 0x00000448; # spi1_cs0_pz6: rsvd1, pull-up, tristate-disable, input-enable, lpdr-disable
#part2
#Just configure the spix_[miso/mosi/sck]_xx as 0x00000444 and spix_csx_xxx as 0x00000448
Bank: 0 Reg: 0x0243d010 Val: 0x00000448 -> spi1_cs0_pz6
Bank: 0 Reg: 0x0243d020 Val: 0x00000444 -> spi1_miso_pz4
Bank: 0 Reg: 0x0243d040 Val: 0x00000444 -> spi1_sck_pz3
Bank: 0 Reg: 0x0243d050 Val: 0x00000448 -> spi1_cs1_pz7
Bank: 0 Reg: 0x0243d058 Val: 0x00000444 -> spi1_mosi_pz5
2: Is the setting like below just useful for loopback test?
#part2
3: I want to make a loopback test, which SPI group doesn’t need any hardware connection can be seted to test? for ex. SPI1 and SPI3, are they ?
Thank you for your patient answer.
Best wishes!
  1. Please apply part2
  2. No, it configure as SPI enable. Loopback test only verify if SPI function working or not.
  3. Just need two SPI to connect like below for example SPI1 and SPI3 for loopback test.
SPI1_MOSI<- ->SPI3_MOSI, SPI1_MISO<- ->SPI3_MISO, SPI1_CLK<–>SPI3_CLK, SP1_CS0 <–> SPI3_CS0 and SPI1_CS1->SPI3_CS1.
Hi ShaneCCC
i want to write a spidev_test.c to make a exe file to realize the reading function only.
Can you give me the -r function code? — ./spidev_test -r --receive only receive data; this should mode |= what ??
Sorry can’t public it due to internal IP concern.
thanks
Now i use the spidev_test you give to me.
Excute the command ,and it always wait, and after ctrl + c , it report the error.
root@dev-desktop:~/lab# ./spidev_test -D /dev/spidev1.0 -s12500000 -O -g6546 -r
root@dev-desktop:~/lab# ./spidev_test -D /dev/spidev1.0 -s12500000 -O -g6546 -r -zzz
using device: /dev/spidev1.0
setting spi mode for read,write
setting spi bpw
setting max speed for rd/wr
spi mode: 2
bits per word: 8 bytes per word: 1
max speed: 12500000 Hz (12500 KHz)
no. runs: 1
Using seed:0x610ce319
loop count = 0
............................................... ----------  wait here
^C transfer ioctl error: -1
/dev/spidev1.0: TEST FAILED !!!!! (status:-1)
====== Transfer stats ====
Receive:
       total: 0B (0KiB 0MiB)
       total: 0P
        good: 0B (0KiB 0MiB)
        good: 0P
       ioerr: 1P
     dataerr: 0P
 Rate:
        good: 0B/s (0KB/s)
        good: 0P/s
 packet drop: -1/10000
  Total time: 5.712006s
And kernel report demsg
[14129.744015] spi-tegra124-slave c260000.spi: waiting for master was interrupted
[14129.744383] spi_master spi1: failed to transfer one message from queue
You can’t use spidev1.0 as master and slave.
i‘m confused that i only want to use the spidev1.0 as slave.
What should i change to make it only become a slave?
OK, please connect the MOSI <–> MISO to run below command.
./spidev_test -D /dev/spidev1.0 -s18000000 -n1 -g64 -zz
What can i do to make the spidev1.0 as slave and only do reading without writing ?
I guess run below command to wait data input from master.
i try and below is dmesg
setting spi bpw
spi mode: 2
no. runs: 1
Using seed:0x610ce9b6
loop count = 0
[15816.830884] ERROR: could not get clock /spi@c260000:osc(2)
................................... -------------- wait here
^C[15822.712953] spi-tegra124-slave c260000.spi: waiting for master was interrupted
[15822.713321] spi_master spi1: failed to transfer one message from queue
Receive:
       total: 0P
        good: 0P
       ioerr: 1P
     dataerr: 0P
 Rate:
        good: 0B/s (0KB/s)
        good: 0P/s
  Total time: 5.884102s
Did you use the pin19/21/23/24/26 ?
Sorry this is spi0 aka spi@321000 aka SPI1_XXX
i use spi1 aka SPI2
Now i find the board has HW problem, HW designed the SPI2_CS only can be used to output, can i make another gpio to be the CS_gpio?
OK, don’t know why get the OSC clocks failed. Maybe need further debug to get more to check it.
You can try use GPIO as CS. Have reference to below relative topic.
