How to configure the file system of emmc+ufs
HI
How can I configure the emmc+ufs file system on the Jetson Orin NX platform? Or, Is this the default configuration? How to confirm that it has been configured?
thanks
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
These two do not exist on Orin NX platform…
HI Wayne
I am using this platform to evaluate new projects. The new project requires the use of big data storage. Initially, I wanted to use a 1TB UFS, but there is no UFS with such storage on the market. Therefore, I would like to ask if it is possible to use both EMMC and UFS simultaneously
thanks
Let me explain this again.
  1. This is Jetson Orin NX forum.
  2. There is no emmc and UFS interface on Orin NX.
Thus, I am not quite sure if you really want to ask this question in this forum…
這邊也用中文解釋一下
  1. 這裡是Orin NX forum
  2. Orin NX平台上沒有eMMC也沒有UFS. 所以基本上你提的東西是沒有辦法做到的…
你確定你的問題是要問在Orin NX上面嗎?
HI
我知道Jetson Orin NX平台上面没有这两个,但是我想知道使用OrinX是否可以实现这个需求。另外,forum上面是只能问etson Orin NX平台本身的问题吗?如果我想了解更多关于客制化的问题可以在forum上提问吗?如果不能是否有其他渠道可以了解这些问题
thanks
如果你想提問客製化的問題請聯繫你們當地的NVIDIA contact window.
好的,明白了
