How to configure the pinmux properly
I would like to know what is the best way to configure the pinmux for each of the 40-pin header GPIOs. Currently, I refer to “Jetson_AGX_Orin_Pinmux_Config_Template_082422” excel file to find the Verilog_Ball_Name for that particular pin. Then, I use that name to search in the “Orin Series System-on-Chip Technical Reference Manual” to find the address and pinmux table for that pin. Then, on Jetson I would type in command: “sudo busybox devmem [address] 32 [value].” I tried testing my way of configuring the pinmux by changing the pull-up/pull-down of one of the GPIO pin, but it doesn’t seem to work. Ex: “sudo busybox devmem 0x02440020 w 0x00008” for pulling up pin15/GPIO27.
Also, some of my pins could only set to output HIGH to about 1.6V [pin 22/GPIO17 & pin18/GPIO35]. I’m wondering if there’s a problem with those particular pins or it is a config issue that can be change by the pinmux.
hello suphakornl,
please refer to developer guide for the steps, Changing the Pinmux.
