What are the changes we need to make in order to configure my xavier to SDIO in DDR50 mode.
I have made the uhs-mask value to 0x08 in dts file which is working in SDR104
I want configure to DDR50 what should be the uhs-mask value and is there any other changes required to make in work in DDR50 mode.
I cheeked it already but current in my dts uhs-mask value in dts file is 0x08 still it is detected as the SDR104 ?? and when i put the 0x8 device itself is not booting ?? what should be the value for the DDR50 ??
Also do we need to any other changes required??
as i can see the sd-uhs-sdr104/sdr50/sdr25 are defined in the dts(I converted the dtb to dts) file but sd-uhs-ddr50 is not defined there do we need to make any other changes?
Thanks,But is it also mentioned we can software can enable DDR50 can you please help in this how enable ?? like uhs-mask value and if any other changes required ??
