I use pointgrey camera and spinnaker sdk
The connection is fine in xavier host, but the following error is output in docker
$ sudo /usr/bin/SpinVeiw_QT
Invalid MIT-MAGIC-COOKIE-1 keyFatal: (null) ((null):0, QXcbConnection: Could not connect to display :1)
Aborted
on my personal PC, I connected to camera in docker with the above command
is your camera listed if you execute the command below?
ls /dev/video*
typically to map a camera smth. like the command below is used
--device /dev/video0
source
My camera is a usb device and the it attached to /dev/bus/usb/002
I think --device option is not a problem
Because I run docker without any difference between the docker run script’s options on the pc.
you also may need to execute
xhost +
reference
and check corresponding parameters e.g.
-v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY
you may also check a thread where a similar issue is mentioned; in the latter case they adjusted Xauthoriy which seems resolved the issue
However, it seems that your issue is not how to connect a camera, but how to map a display.
my run script already has
XSOCK=/tmp/.X11-unix
VOLUMES=“–volume=$XSOCK:$XSOCK:rw”
ENVIRONS=“-e DISPLAY=${DISPLAY}”
what else does your run script have?
what code do you execute when getting the error?
could you provide the complete docker run sequence?
DaneLLL
February 13, 2020, 5:24am
7
For USB cameras, we support UVC driver by default. You may check this post
If the cmaera does not support UVC driver and requires additional driver, we would need community to share experience.
I use a grasshopper3 camera and support a USB3.0 cable.
Unfortunately the advice of using UVC driver is not the solution in my case.
my case’s are:
~$ v412-ctl -d /dev/video1/ --list-formats-ext
bash: v412-ctl: command not found
~$ gst-launch-1.0 v412src device=/dev/video1 | video/x-raw format=yuy2,width=848,height=480,framerate=30/1 | nvvidconv | ‘video/x-raw(memory:NVMM),format=NV12’ | nvoverlaysink
bash: video/x-raw: No such file or directory
bash: video/x-raw(memory:NVMM),format=NV12: No such file or directory
bash: nvvidconv: command not found
bash: nvoverlaysink: command not found
ERROR: pipeline could not be constructed: no element “v412src”.
oops! There was a mistake
~$ gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=848,height=480,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
WARNING: erroneous pipeline: no element “nvvidconv”
this is in my case.
DaneLLL
February 13, 2020, 9:30am
10
First, I checked for installing/running docker, but
my case is
~$ sudo dpkg --get-selections | grep nvidia
[sudo] password for :
libnvidia-container-tools install
libnvidia-container0:arm64 install
nvidia-container-csv-cuda install
nvidia-container-csv-cudnn install
nvidia-container-csv-tensorrt install
nvidia-container-csv-visionworks install
nvidia-container-runtime install
nvidia-container-toolkit install
nvidia-docker2 install
nvidia-l4t-3d-core install
nvidia-l4t-apt-source install
nvidia-l4t-bootloader install
nvidia-l4t-camera install
nvidia-l4t-ccp-t186ref install
nvidia-l4t-configs install
nvidia-l4t-core install
nvidia-l4t-cuda install
nvidia-l4t-firmware install
nvidia-l4t-graphics-demos install
nvidia-l4t-gstreamer install
nvidia-l4t-init install
nvidia-l4t-initrd install
nvidia-l4t-jetson-io install
nvidia-l4t-jetson-multimedia-api install
nvidia-l4t-kernel install
nvidia-l4t-kernel-dtbs install
nvidia-l4t-kernel-headers install
nvidia-l4t-multimedia install
nvidia-l4t-multimedia-utils install
nvidia-l4t-oem-config install
nvidia-l4t-tools install
nvidia-l4t-wayland install
nvidia-l4t-weston install
nvidia-l4t-x11 install
nvidia-l4t-xusb-firmware install
~$ sudo docker info | grep nvidia
Runtimes: nvidia runc
Second, v4l-utils were already installed. but,
~$ sudo v4l2-ctl -d /dev/video1 --list-formats-ext
failed to open /sys/dev/char/0:0/uevent
and
~$ sudo gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=848,height=480,framerate=30/1 ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=NV12’ ! nvoverlaysink
Is there no way??
how do you run the docker container?
could you share the exact script, please?
DaneLLL
February 20, 2020, 8:00am
13
We have two docker packages for L4T(Jetson platforms):
FYR and you may give it a try.
