How to connect a deepstream docker container with proto
• Hardware Platform (Jetson / GPU) Jetson nano 2gb
• DeepStream Version deepstream 6.0.1
• TensorRT Version
• Issue Type( questions, )
In using or creating the deepstream docker container for IoT or samples.
How do I connect it to the proto, in this case, our proto is AWS. AWS proto can be created here
Sorry for the long delay.
Have you successfully run the AWS sample yet? Sorry this is an AWS issue, I can’t do nothing.
Can you point me to someone on the AWS platform I can talk with
