How to Connect IB QM9700 to IB SB7800 switch
Can we connect from QM9700 to SB7800 switch? I understand that NDR using 4x100Gbps PAM4 but EDR useing 4x25Gbps NRZ. I’m not sure NVidia has such cable or we need to connect as QM9700—QM8700----SB7800.
EDR to NDR direct connectivity has never been validated or supported, you would need to connect through an HDR switch.
The documentation does show that there may be a way to connect these as shown below, however this is not supported.
For QM9700 → SB7800 direct copper, use the MCP7Y60-Hxxx passive DAC splitter family: MCP7Y60-H001 (1 m), MCP7Y60-H01A (1.5 m), or MCP7Y60-H002 (2 m). NVIDIA’s LinkX portfolio maps these as the direct-attach path from a QM9700 twin-port OSFP side to 2×100G EDR links for SB7800 QSFP28 ports, and the cable spec says the switch/adapters can downshift to 4×25G NRZ for EDR InfiniBand.
Two important limits:
  • EDR on QM9700 copper is supported only up to 2 m.
  • One QM9700 OSFP cage contains 2 logical InfiniBand ports, so one MCP7Y60 cable gives you two 100G EDR links into two SB7800 ports.
We have connected a 7800 to an 9700 using the MCP7Y60-H002 cable.
ibnetdiscover shows all the hosts connected to both switches, however IPoIB won’t come up on the hosts connected to the 9700.
The subnet manager with the highest priority is the one running on the 7800.
Is the lack of IPoIB likely to be just the the old subnet manager not allowing the new 400G hosts as they are outside it’s spec? i.e. If I move the subnet manager to the 9700, or to opensm on one of the hosts it may work?
