I have a idea about build a docking station, to separate GPU from SFF-size workstation, which the power supply and heat exchange in air cooling is limited. the main function of this docking station is the PCI-E socket connection board to build a communication between eGPU and infiniband adapter(SFF PC–Adapter–Adapter–GPU) as simple as possible. Is that will be availble to connect Nvidia infiniband adapter and Nvidia RTX GPU card DIRECTLY via PCI-E socket connect board(contain power supply and PCI-E lane retimer) in technical? Will the chips in Nvidia infiniband adapter can be the controller like PCI-E controller and DMA controller, what there function are in regular mother board construction by specific change of configuration? Or to make it work, what external circuit should it have in PCI-E socket connection board? Or another solution to make it?
Related topics
Topic | Replies | Views | Activity | |
PCI-e Device to Device Transfers | 4 | 7488 | September 22, 2010 | |
Adapter hardware compatibility | 1 | 384 | January 4, 2018 | |
8880 GTX + on-board VGA adapter | 11 | 9889 | September 22, 2007 | |
Is it possible to use ConnectX-4/5/6 and an appropriate switch to create a 50GBe or 100GBe infiniband between 4 desktop computers with i9-12900K, z690 DDR5 motherboard and RTX A6000/A100? Not sure if enough pcie lanes and if viable between desktops | 1 | 399 | January 26, 2022 | |
I need help with using InfiniBand in my data center | 1 | 854 | July 27, 2021 | |
NVidia GPUs in Embedded Computing Has the GPU computing and CUDA penetrated the embedded market? | 11 | 3881 | August 3, 2010 | |
GPU to GPU direct data transfer with connectX and RDMA | 2 | 75 | May 19, 2025 | |
PCIe device-to-device transfer Transfering data from PCIe Frame grabber to CUDA GPU | 0 | 2201 | July 18, 2011 | |
On-board GPU for display? | 6 | 5205 | November 10, 2011 | |
GPU Direct 2.0 (GPU to external device) GPUDirect | 0 | 9273 | June 8, 2011 |
