In the beginning, I use HDMI display to look log but it is not convenient.
I check TX2, it uses UART0 (H12, G12, H11, G11) for debug and uart0 is on J10 (pin 6, 8, 10, 12).
This following sentence is from “Jetson_TX1_and_TX2_Developer_Kits_User_Guide.pdf” If a serial console on the Linux host is desired, a serial cable must be plugged into the serial port J1A2 UART4 on the target and connected to your Linux host directly or through a serial-to-USB converter
I don’t know how to connect J10 to host pc. Is there anyone can give me suggestion?
BTW, I also saw the information that shows UART1 is the serial console on the Jetson TX2.
Use J21. Note that in some cases labels/numbering may differ depending on whether you are looking at the module or if you are looking at the carrier board (it is confusing, but in reality the carrier and the module are separate products). Use settings 115200 8N1, software (no) flow control.
