I have developed applications in jetson nano using python. my application requires wifi to make the api calls. I am planning to run my script on boot. When i start my script, i need to wait till my board connects with wifi, if it is connected only i need to move forward or else it should keep on wait to connect.
Is there any suggestion for python script related to my requirement?
Hi, I have solved it using a startup application in ubuntu. But now problem is that, when the system starts booting, it is waiting for an authentication password, after I am entering the password only my program service is getting started. If I remove the authentication process then my device becomes unsecured.
So how to secure my device after removing authentication?
how about setting-up SSH for your host and target device.
you should create a SSH keypair, and copy the keypair to the target board with ssh-copy-id.
the roughly settings looks like following,
Setup SSH on device (Jetson platform)
i.e. ssh-keygen -t rsa
Setup SSH on host machine, using the same passphase to get access.
i.e. ssh-copy-id <account>@DEVICE-IP-Address
