I’m using a Jetson Orin Nano in a robotics context, as part of a larger system. The Jetson is the central control unit for our part of the system. I need to ensure we can initially boot, boot when power cycled, etc. Here’s the behaviour of the Jetson, as far as I have discovered:
Physically connecting the DC barrel jack causes it to boot. This is not an option in the remote context.
If the Jetson is already on, and it is power cycled (without removing the jack), it will boot. This is good.
If the Jetson has been shut down properly, via the OS, it will not boot if power cycled (without removing the jack). So if we do a safe shutdown, it becomes difficult to bring it back up.
On the button header, it’s possible to trigger a boot by connected the power button pin to ground. This is useful, but also dangerous: Keeping the pins connected shuts the Jetson down, and if the Jetson is already on, connecting the pins briefly causes it to shut down. So I’d rather not use these pins at all.
I have heard a rumour of being able to boot via UART. Or possibly I could use wake-on-LAN. Can I get some advice?
Since reconnecting the barrel plug boots the board, Auto-Power-On is working. The different result from your remote power cycle suggests that the DC input may not be dropping fully after shutdown.
Recommendation: Keep J14 pins 5 and 6 open, and have the external controller remove and reapply DC power at J16 after the OS shutdown completes. Verify that J16 reaches 0 V while power is off; switching only the adapter’s AC input may leave residual DC voltage.
J14 pins 11 and 12 are the SLEEP/WAKE* input. As you observed, using them while Linux is running can initiate shutdown, so they should only be controlled when the system state is known.
UART is not documented as a power-on method. Wake-on-LAN can wake the system from suspend, but not from the Off state after an OS shutdown.
Thanks. Please confirm so I understand: The auto-power-on should work in all power-cycle cases (including after shutdown), without requiring physically removing the barrel jack. There is no intended behaviour around physically plugging the barrel jack, the behaviour is solely electrical. Is that correct?
