How to continuously feed h264 data to HW decoder
We have two samples for video decoding. You may use NvVideoDecoder class, or direct v4l2_ioctl calls. If the input h264 stream is in IDR P P P…, decoder would need to keep at least one reference frames. You would need to preload minimum two frames. For law latency, please set --disable-dpb.
