I am using Xavier DevKit with L4T R35.1 and would like to control the CAM_RST1 signal (connected to PWDN pin of max9296) on the Des(mmax9296B) board. the signal is connected to Xavier DevKit board via LI-JXAV-MIPI-ADPT-4CAM board manifactured by LEOPARD.
The CAM_RST1 looks like connected to Pin #95 of the camera connector on the Xavier Dvekit board which is connected to UART4_TX(ball name) on Xavier SoC.
I found out hte UART4_TX is GPIO.PH03(cutomer usage) in Pinmux file(Jetson_AGX_Xavier_Series_Pinmux_Configuration_Template_v1.4.xlsm) .
Then I checked the the CAM_RST1 signal on the Des board with a oscilloscope as the following procedure.
But I could not find any change on the signal. It is always High(about 1.8V) after several micro seconds from turning on the Xavier DevKit.
Is my procedure wrong ?
$ sudo su
# cat /sys/kernel/debug/gpio | grep PH.03
gpio-382 (PH.03 |camera-control-outpu) out lo
# echo 382 > /sys/class/gpio/export
# ls /sys/class/gpio/
export gpiochip305 gpiochip335 gpiochip504 PH.03 unexport
# echo out > /sys/class/gpio/PH.03/direction
# echo 1 > /sys/class/gpio/PH.03/value
# grep PH.03 /sys/kernel/debug/gpio
gpio-382 (PH.03 |sysfs ) out hi
# echo 0 > /sys/class/gpio/PH.03/value
gpio-382 (PH.03 |sysfs ) out lo
Any advice/help is appreciated.
Thank you,
k.iwasaki
