• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5
• TensorRT Version 7.1
**• NVIDIA GPU Driver Version (valid for GPU only)**440+
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) Question
I want to control the fps of the pipeline for rtsp source. Example - I need a parameter like fps=10
. So that the pipeline runs at 10 or less fps.
I could not use drop frame interval
, because a rtsp stream can have variable fps and we may not know the fps of the rtsp streams.
