I run the people samples referring to the docs using extensions and UI: Omni.Anim.People — Omniverse IsaacSim latest documentation
But I wonder if there are ways to directly use Python API to control people’s animation in Isaac?
Looking forward to replies, thank you so much.
You can check an example here
https://pegasussimulator.github.io/PegasusSimulator/source/tutorials/create_simulation_with_people.html
This is not the “ideal” solution, but it gets the job done.
Best,
Marcelo
Thanks for your reply. I will see the example and find the solution.
