Hi I can see there is this variable in GstNvInferFrame given below.
/** Pointer to the converted frame memory. This memory contains the frame
- converted to RGB/RGBA and scaled to network resolution. This memory is
- given to NvDsInferContext as input for pre-processing and inferencing. */
gpointer converted_frame_ptr;
which is coming from GstNvInferMemory
/** Vector of pointer to individual frame memories in the batch memory */
std::vector<void *> frame_memory_ptrs;
and same is being used in gstnvinfer.cpp like this to access.
memory->frame_memory_ptrs[idx]
i want to know if there is a way i can convert this to opencv format or some kind usable format to process. i cannot find any more document for this particular variable.
please let me know.
We have sample code in dsexample plugin. Please look at
deepstream_sdk_v4.0.2_jetson\sources\gst-plugins\gst-dsexample
It is in get_converted_mat()/gstdsexample.cpp
Furthermore, you may refer to this post for using cv::cuda APIs:
https://devtalk.nvidia.com/default/topic/1047620/deepstream-sdk/how-to-create-opencv-gpumat-from-nvstream-/post/5397368/#5397368
Ok i have tried to the same. and i am getting weird image. i am attaching one sample.
i am using below code in the function convert_batch_and_push_to_input_thread after NvBufSurfTransform.
Not sure what is going wrong.
static gboolean
convert_batch_and_push_to_input_thread (GstNvInfer *nvinfer,
GstNvInferBatch *batch, GstNvInferMemory *mem)
NvBufSurfTransform_Error err;
std::string nvtx_str;
cv::Mat in_mat;
/* Set the transform session parameters for the conversions executed in this
* thread. */
err = NvBufSurfTransformSetSessionParams (&nvinfer->transform_config_params);
if (err != NvBufSurfTransformError_Success) {
GST_ELEMENT_ERROR (nvinfer, STREAM, FAILED,
("NvBufSurfTransformSetSessionParams failed with error %d", err), (NULL));
return FALSE;
nvtxEventAttributes_t eventAttrib = {0};
eventAttrib.version = NVTX_VERSION;
eventAttrib.size = NVTX_EVENT_ATTRIB_STRUCT_SIZE;
eventAttrib.colorType = NVTX_COLOR_ARGB;
eventAttrib.color = 0xFFFF0000;
eventAttrib.messageType = NVTX_MESSAGE_TYPE_ASCII;
nvtx_str = "convert_buf batch_num=" + std::to_string(nvinfer->current_batch_num);
eventAttrib.message.ascii = nvtx_str.c_str();
nvtxDomainRangePushEx(nvinfer->nvtx_domain, &eventAttrib);
/* Batched tranformation. */
err = NvBufSurfTransform (&nvinfer->tmp_surf, mem->surf,
&nvinfer->transform_params);
std::cout<<nvinfer->transform_params.dst_rect->width<<" "<<nvinfer->transform_params.dst_rect->height;
nvtxDomainRangePop (nvinfer->nvtx_domain);
("NvBufSurfTransform failed with error %d while converting buffer", err),
(NULL));
return FALSE;
// Map the buffer so that it can be accessed by CPU
// if (NvBufSurfaceMap (mem->surf, 0, 0, NVBUF_MAP_READ) != 0){
// return FALSE;
// Cache the mapped data for CPU access
NvBufSurfaceSyncForCpu (mem->surf, 0, 0);
in_mat = cv::Mat (1080, 1920,CV_8UC4, &mem->surf->surfaceList[0].mappedAddr.addr[0],mem->surf->surfaceList[0].pitch);
cv::cvtColor (in_mat, in_mat, CV_RGB2BGR);
cv::imwrite("out1.jpg",in_mat);
g_mutex_lock (&nvinfer->process_lock);
/* Push the batch info structure in the processing queue and notify the output
* thread that a new batch has been queued. */
g_queue_push_tail (nvinfer->input_queue, batch);
g_cond_broadcast (&nvinfer->process_cond);
g_mutex_unlock (&nvinfer->process_lock);
return TRUE;
There are samples of saving to JPG. Please refer to 2, 5 in FAQ
