Software Version
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other
Host Machine Version
other
Hi Community,
I am currently dealing with a segmentation model whose output blob dimensions are [640. 480, 26]. Each pixel contains 26 probabilities. I assign every pixel the index of max probability for that pixel and then, changing the class label with its RGB color, thus converting the output to [640, 480, 3]. I do this by looping through the pointer.
This is very inefficient and am also not able to convert the 3D vector to ImageGL for rendering. I have shared the conversion I want below:
std::vector<std::vector<std::vector<uint32_t>>> mask_vector <-> dwImageGL mask_gl;
I would like to know a method which is more tightly integrated into the driveworks frameworks and is fast.
Dear @priyam1,
Could you please confirm the used platform if it is DRIVE AGX ORIN Devkit?
Dear @priyam1,
As this post processing is specific to your network, you need to implement as per the requirement. I am assuming this post processing step in happening on CPU now. How about using a GPU kernel to convert [640. 480, 26] to [640, 480, 3]?
Dear @SivaRamaKrishnaNV ,
Before getting into this post-processing, I would like to know whether the output i get from dwDNN_inferRaw
contains the same dimensions as the outputBlob, or is it a linear vector which i will have to convert into a 3D array. The reason, I am asking this is because i only have an outputDevice pointer pointing to the output in the CUDA memory and I don’t have a way to validate its dimensions.
My Output blob dimensions are [26, 480, 640]
. Is this an pointer to dwImageCUDA
or something?
Dear @priyam1,
dOutput
param in dwDNN_inferRaw
is an array of output buffer pointers. If your network has two output buffer. This param
holds two pointers. Each output pointer points to CUDA device pointer(dptr
in dwImageCUDA
As I understand, output buffer in your case should be linear memory of size 26*480*640
in your case. You can access it directly inside a CUDA kernel for verification or copy to CPU buffer using cudaMemcpy()
@SivaRamaKrishnaNV The output is stored in linear memory. But, is the linear memory contiguous or is there some pitch/stride/offset assigned to it. If there is, then how can I find the pitch/stride/offset of the model output.
Dear @priyam1,
As I understand, It should be single array with 26*480*640
size. Please check accessing inside a cuda kernel or copy to CPU with for verifcation.
