I trying to convert YoloV3-Tiny-PRN to TensorRT model to use in DeepStream SDK on my Jetson Nano. But i’m having problems with shortcut conversion because PRN uses:
[shortcut] activation=leaky from=8
and default yolo models uses:
[shortcut] activation=linear from=-3
How can I edit engine to convert yolov3-tiny-prn to TRT?
Error seems to be because of input dimension mismatch:
Input dim to layer 22 and 25 layers are:
26x26x128 and 26x26x256
In TRT, Elementwise operation should statisfy following condition:
For each dimension, their lengths must match, or one of them must be one. In the latter case, the tensor is broadcast along that axis.
